Replacing Dell H1000E-01 1000W Power Supply
Andrew_P
Hello I have had my Dell XPS 730x for a while now and about 5 months ago i shut down my computer as normal and the next morning i turned it on and the power button began to flash.
None of the components of the computer started up the only thing that happens is you can hear a little click when you press the power button the first time. And if you hold your power button again you hear another click.
I have done a lot of research on this and found another thread on here with the exact problem as me, and his solution resulted him in replacing his power supply. He only stated that he replaced the psu with a cheap one and it worked.
My question is what is a replacement for my psu? And i don't really want a 1000W psu because my computer doesn't use that much i was looking for something more like 600-700W.
I have disconnected the wiring harness from my power supply so that i don't have to unplug everything from the mobo.
