When I built my new desktop earlier this year, i7 7700k (OC to 4.8GHz), Asus Z270-F, 16GB RAM and a EVGA 1080 SC, I stuck a random array of fans in my NZXT H440 case to try and help it cool. Although it worked out fairly well, a couple are now starting to rattle. I am planning on replacing allfans in the case with some Noctua NF-F12 120mm PWM Chromax (3 on the top and 3 on the front, already have a Noctua one on the rear for exhaust), don't particularly like the colour of the normal NF-F12. Are these fans worth the money or are there better ones out there? Would preferably like a quiet fan
I was wondering if it would be worth while investing in a fan controller since I am planning on having 7 fans in the case? Was looking at potentially a NZXT Grid V3 since the H440 doesn't have a DVD drive bay. The fan hub in the case now doesn't really offer much in the way of customisation in fan speeds.
Also been having a slight issue with the CPU fan. I am using a be Quiet Dark Rock 3 cooler and although it helps to keep the CPU cool, when I load an intensive app, a game for example, the temperature will spike about + 20/25 degrees for 1 or 2 seconds resulting in the CPU fan running at 100%. Although only a slight inconvenience, the fan is quite load at 100% and can get annoying when the CPU random spikes every 10 minutes or so. I was wondering if there is a way to run the CPU fan at 70-80% constantly since at this speed (altered in the BIOS to find out) the fan is fairly quiet and keeps temps down. Asus fan control software only allows you to run the fan at 80% up until 75 degrees,at which point it must be ran at 100%, which the random spikes make the temperature go past that?
