So I just installed the Kraken x72 water cooling system in my build and love it. A few things however:
1) the fans are noisy
2) i would like rgb fans in their place
Which fans are most compatible with this water cooling system and what would I need to install it and make it work. I like the way the NZXT AER rgb fans look but if they would be difficult to configure with the system i am open to other options like thermaltake riing which I know are static pressure which are theoretically mean to for watercooling. Is static pressure necessary or can I go with the NZXT AER? Thanks.
