Hey there,
I have purchased a Force 1761 (MS-1761) laptop from xoticpc.com in 2011, but now the video card need replacement.
Specs:
i7-2630QM, GTX 570M, 8GB RAM
The person in the repair shop said they can't replace the GPU however I started reading and while I found some people having problems with upgrading (especially with 770,780M cards) I have also read good things about 870M.
Additionally:
"Yes, the GTX900M Series runs without any problems in the MS-1761 Barebone. This Series works in all MSI Barebones." (source: http://forum.techinferno.com/msi/10710-gt780dx-upgrade-gtx-9xxm.html)
Can you confirm that this is the case? If yes, would 870 and 970 both work?
Or is there other or better options?
Thanks a lot for any help
Balint
Specs:
Additionally:
Balint
