Replacing Motherboard HELP!
FRESH_TACOS
9
Hello everyone I need to replace my mobo to upgrade to SLI because my mobo doesn't support it. Will I need to reinstall OS? This is my build right here http://pcpartpicker.com/p/nhZwXL and I'll be getting an ASUS Z97-A and then having a second 770. Can I just put a new mobo in there and everything will work itself out or will I have to do a clean wipe because I don't really want to :/ thanks guys!
If I understand correctly, you are moving from the Z97M to the Z97-A ? If so I consider something with better performance and less negative user reviews:
Gigabyte or MSI Gaming 5 are in the same price range
Asus Z97-A ($143) gets 23% negative (1 egg) reviews
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132118
Gigabyte Gaming 5 ($130) gets 10% negative (1 egg) reviews
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128709
MSI ($135) Gaming 5 gets 10% negative (1 egg) reviews
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770
And yes, a re-install is recommended.
