Replacing my CPU going wrong!
tombritten
17
Hey guys!
I have bought a CPU i7 6700k 4.0GHz to replace my i5 6400 2.7GHz (both socket 1151LGA). For some reason when I replace the CPU, the CPU fan goes crazy as in its working on a constant 100% and I don't know why? Note: The computer works fine with the new cpu installed, turns on and I can access averything as normal.
- Ive bought and installed new thermal paste. Nothing.
- Ive checked the temperature of the new CPU temp and its about 30 degrees.
- When re-installing the old CPU the fan is fine and works at a normal rate.
Just so we're clear, I'm using the same fan for both, I only bought the chip.
I have no idea what's going on! Any help would be amazing.
Thanks in advance!
Tom
The joy of upgrading prebuilt machine - you never know what devil sits in the box.
Can't help you with watercooler as I never used any either. But, maybe there's a workaround. If you could connect CPU fan to some other header normally used by case fan, there's a chance you could make it work with varying speed based on CPU temp (such settings should be even in so much limited BIOS). However, the system might not boot when nothing is connected to CPU_FAN. So you would need to connect one of case fans to CPU_FAN header; it would run full speed but if you would use silent low-rpm fan, it would not be a problem.
Trick no 2, swap the fan on cooler to silent one. As far as I can see on pictures, the fan is screwed to the heatsink, so it...
What cpu would you recommend?
Yes cooler I mean. I'm not sure about what motherboard I have, I have an alienware aurora R5. And I'm not going to overclock it.
Haha yeah.
I wasn't sure how to add photos in-line so I've added them to my G.Drive. See the link below:
https://drive.google.com/drive/folders/0BwIboHVSpnyzS05oUERYMk1LRzQ?usp=sharing
Thanks again for your help!
That's definitely not stock intel cooler. However, I don't think it's beefy enough for 6700K. But there's awfully low amount of space for the cooler on that board. It would have to be something powerful but small. Note how close the ram sticks are to the fan. It's a 120 mm fan or 140 mm?
I'm not sure, I don't have anything to measure it with but I've added 2 new photos in the folder on drive so you can get more of an idea about how close to the ram it is.
I bought it with a GTX 1070 in it so yeah, I want to do a bit of gaming on it.
This thing was made by Dell, right? So I would contact their customer support first, and try to get answer to simple question: does the motherboard has standard cooler mounting system? Then I would measure available space (all three dimensions) to see how big cooler can fit. Without that data it is hard to make any reasonable decisions.
Ok great thanks Dragor. I'll check and get back to you tomorrow!
In the meantime, could you do a little test? Run your most CPU-heavy program or game for about half a hour and record max CPU. If not above 70 C, extend test to 1 hour. That way we will know if current cooler is capable of keeping your new CPU under control.
Sure! Ill see when I get back from work!
Yeah mate, the fan is fine. What I did notice is that on the alienware thermal system the cpu cooler isnt there, it appears as a pump. which is weird? I spoke to a guy at Maplin (a computer hardware store) and he basically said that it's picking the fan up as a water cooler which is weird! But it doesn;t with the other chip?
That's possible. Look at the specs of your machine at net: there are several versions, and the pictures show water cooling system. My guess is water cooling is mounted in systems with 6700k, and the BIOS might be hard-coded to think that if it has 6700k installed, it also has water cooling installed. Since in water cooling the pump is set to work on full speed all time, it makes sense - BIOS thinks your fan is pump and sets it to full speed.
So, if the temps were good in the test, you can try to change BIOS settings so it will use it as fan again. IF it is possible, since this is special motherboard build for this very system, I suppose BIOS options are quite limited. But it's worth trying anyway.
Hey mate, just got off the phone to Dell tech support and yes basically becuae its an i7 it thinks its a water cooler so will run at 100% all the time. I went into the bios and there is no way to change this... my only option is to buy a watercooler :/ im not sure about them though, never used or installed one. Not even sure where to start!
Trick no 2, swap the fan on cooler to silent one. As far as I can see on pictures, the fan is screwed to the heatsink, so it should be possible to replace it. Actually I think this is best way to solve that problem. All you would need is to find same size fan that will be silent even on full speed.
Ok great massive thanks for your help! Im going to try with a water cooler and get it installed!
