replacing speaker system
What's your budget?
Are you looking at 2 speakers configuration or you prefer 2.1 (2 speakers and a sub), 4.1, 5.1, etc.?
Take a look at:
Logitech z533
Cyber Acoustics CA-3602
the cheapest ... guessing 2 speakers not really a gamer ... not sure got lost on configuration 🙁 maybe not the cheapest hoping pc last another 13 yrs ... thx for respond
Logitech z533
Cyber Acoustics CA-3602 either ones....do i need adopters , not sure what to do pc was given to me mint condition only thing missing were speakers
You don't need any adapters, they both use standard stereo 3.5 mm connections. Just make sure your PC sound is working.
If I remember correctly that PC has a green 3.5 mm connection on the back, where to connect speakers, between the pink Mic and blue In connections.
It also have two 3.5 mm connections in the from (Mic & headphone).
Connect a headphone to the front 3.5 mm jack and the green 3.5 mm jack on the back then play a music file.
Make sure the volume in the PC is not mute.
That way you will know if there is sound before purchasing the speakers.
thx ...plug in old speaker and trouble shoot sound problem fixed to default ...thanks again now to learn window 10 the struggle is real ....hopefully I will be able to learn how to to keep pc in tip top shape I'm an awe that it works so good thanks for your help <30
. Bigger problem
