Replacing thermal paste and cooler in Intel i5-2500K
Oscarmk
114
I've been using my i5-2500K since 2012, and it has always run stock 3.3 with turbo boost to 3.7 Ghz. I recently got a new 1070 Ti to replace my HD 7850 that died, and now that I am pushing everything to max, I can see in RealTempGT the CPU goes to 70 C even after just 30-45 mins of normal gaming.
I would like to replace the thermal paste, I have seen some videos on how to do it, but the videos I have found are removing the thermal paste from the cooler. I will be using normal 70 alcohol and coffee filters, unless 90 is needed, in which case I can buy one. My biggest question is how to handle the CPU while I am cleaning it as I don't want to be touching the pins do I just grab it from the edges with one hand and clean it with the other?. Can I set it any surface while cleaning it, I have an anti static wrist band but I am concerned about the pins getting dirty.
I was thinking if I could remove the stock intel cooler, leave the CPU clamped and clean it right there?, in this case I would just wet the coffee filter and clean it right there, rather than dumping the alcohol on it of course. Once it is clean, I was thinking of getting a Cooler Master Hyper 212 cooler, which already comes with "cooler master" paste, I have Artic Silver 5 that I never used but its from 2012, should I just use the cooler master paste or get another tube of silver 5 after cleaning it with coffee filters?. My motherboard is an ASUS Maximus IV Gene-Z/Gen3 LGA 1155 Z68.
Finally if everything goes well and temps go down, which I fully expect after replacing the thermal paste and getting a better cooler than the stock cooler, assuming temps go down significantly I wanted to do a modest overclock to 4 or 4.2 Ghz, would the Cooler Master Hyper 212 work for this?. House is always with AC on, so temp is usually 23-24 C inside the house.
Also any good videos that go over the process of removing the old cooler, removing the old paste, applying new paste and applying a new cooler would be perfect.
Thank you.
Your temperatures are good for that cooler.
Specs say you have only 144mm available for a cpu cooler.
That leaves out the cryorig H7 which is 145mm tall.
Love the maximus VII gene; had one some time ago.
If you want to pursue a better cooler, Look at noctua.
I think the NH-C14s will do it.
Noctua maintains a comprehensive list of compatibility for various motherboards.
Here is the one for the Maximus VII gene.
https://noctua.at/en/mainboard/Asus_Maximus_VII_Gene
If you are interested in better cooling, change out your case for a more modern one.
I use the Silverstone TJ-08e.
What is your idle temperature?
I expect to see 10-15c. over ambient with the stock intel cooler.
70c is a very normal temperature to see under load.
The cpu will throttle or shut off if it detects a dangerous temperature.
That is around 100c.
What is your case?
What is your fan arrangement?
Any cooler needs a good source of fresh air to do it's job.
When replacing a cooler leave the cpu in the socket.
A socket has a design point of 15 insertions, so do not remove the cpu without cause.
You can easily damage pins if you re insert badly. Not good.
If you heat up the cpu by running it before the job, the old cooler will come off more easily.
If you touch the case before working, you will discharge any residual static.
I use paper coffee filters to do the cleaning job.
Mainly because they are lint free.
I tear off a piece and put a bit of alcohol on the piece and wipe of some of the paste from both the cpu and the cooler.
Repeat with new strips until you get all of the paste off.
It will take perhaps 5 passes until the last one is completely clean.
All paste is ok.
AS5 is one of the ones I use, but the paste that comes with a cooler is ok too.
Be careful about using too much paste as it can act as an insulator.
A rice sized drop in the center will spread under heat and pressure.
It is hard to use too little.
If you are going to overclock the 2500K(and I think you should) then a better cooler is in order.
Assuming you have 160mm available for a cooler like the hyper212, then I recommend the scythe kotetsu@$35.
https://www.newegg.com/Product/Product.aspx?Item=13C-0004-00005
I was impressed when I installed one in my son's pc with a 7600K overclocked.
Very quiet.
Here is a review:
http://www.silentpcreview.com/article1391-page1.html
In the event you want to try reinstalling the pushpin cooler, here is a copy of my stock instructions:
----------------how to mount the stock Intel cooler--------------
The stock Intel cooler can be tricky to install.
A poor installation will result in higher cpu temperatures.
If properly mounted, you should expect temperatures at idle to be 10-15c. over ambient.
To mount the Intel stock cooler properly, place the motherboard on top of the foam or cardboard backing that was packed with the motherboard.
The stock cooler will come with paste pre applied, it looks like three grey strips.
The 4 push pins should come in the proper position for installation, that is with the pins rotated in the opposite direction of the arrow,(clockwise)
and pulled up as far as they can go.
Take the time to play with the pushpin mechanism until you know how they work.
Orient the 4 pins so that they are exactly over the motherboard holes.
If one is out of place, you will damage the pins which are delicate.
Push down on a DIAGONAL pair of pins at the same time. Then the other pair.
When you push down on the top black pins, it expands the white plastic pins to fix the cooler in place.
If you do them one at a time, you will not get the cooler on straight.
Lastly, look at the back of the motherboard to verify that all 4 pins are equally through the motherboard, and that the cooler is on firmly.
This last step must be done, which is why the motherboard should be out of the case to do the job. Or you need a case with a opening that lets you see the pins.
It is possible to mount the cooler with the motherboard mounted in the case, but you can then never be certain that the push pins are inserted properly
unless you can verify that the pins are through the motherboard and locked.
If you should need to remove the cooler, turn the pins counter clockwise to unlock them.
You will need to clean off the old paste and reapply new if you ever take the cooler off.
Thank you so much for the very detailed response, I am not home right now. But I remember seeing 38c idle for the cpu, usually 40 I remember. I remember assemblying everything outside the case and seeing videos about proper installation also remember the pins going thru 6 years ago. I have this NZXT case which I must say is pretty great: https://m.newegg.com/products/N82E16811146069?0p19G=c , bought it 6 years ago and its awesome. Seems height is only 20.5 cm, I didn’t know cpu coolers where that big so it might not fit, Is the horizontal area the same?, are there coolers not as tall?. With the side fan, and the motherbord standoffs it probably will clear 160 mm height, how about surface area? i have maximus iv gen3/gen-z 1155 asus board: ASUS Intel LGA 1155 - Z68 PCIe 3.0 -... https://www.amazon.com/dp/B006L6ZISG?ref=yo_pop_ma_swf . I am using all 4 ram dimms next to the cpu. 16 gb ram total.
Just got home and checked temp, right now ambient is 25.5 and min temp in one core is 33 others 36, seems to be between 36-38 idle.
I've just (as in 2 hours ago) upgraded the stock cooler on my 2500k running on an Asus P8-z68v Pro/Gen3 with a Corsair H100i V2, I was idling at 45C on the stock cooler and any stress test i ran had it hitting the 90C mark and thermal throttling badly.
With the Corsair unit installed it now idles at around 28C and an hour long stress test had it maxing out at around 49C.
Room temp was 24C.
I removed the CPU and used Isopropyl alcohol w/ cotton buds to clean the old thermal goop off, and them just used the preinstalled Corsair thermal pad.
Just thought i'd give you an idea of what my experience was.
9Cqj1qP
UAbkzLo
Wow those results are truly impressive, thank you for sharing, I looked up the Corsair H100i V2 but I don't think I have nearly enough space for it :) . I think I will get the NH-C14s which seems is good with the Maximus IV as well as my case given the noctua website and the NZXT clearance specs for my case.
I just received the NH-c14s and looking at it and my maximus IV gen-z/gen3 I see no way this can clear the first pci express slot, It says it should here: https://noctua.at/en/nh-c14s/comp
But there’s simply no way I can see it can, this is how it looks currently, took this photo before replacing the video card with the 1070, but its the same space now:
Yeah, i have a Corsair 650D and it fit really nicely into the top mounting brackets.
Did you sort your cooling out?
How does the 1070ti work in your config? i'm looking to replace my 6950 (still works fine but the new gen games are giving it a little bit too much trouble.
Gotta say though, they do run and that little 2500k is still a champ 6/7 years on.
I just mounted it, it took me a couple of hours because it was a very tight fit in my case, was hard to connect the fan because of my top case fan, but finally I got it. It clears the 1070 ti just barelly by like 5 milimeters, the fan’s clip sticks a tiny bit more and its only about 3 mms from the 1070 ti backplate, but yes it does fit lol. It doesn’t seem like it bends at all, so I think it will be ok. I contacted noctua just in case and they said that it is a tight fit but it is fine.
It also took me a long time because the first step in the noctua manual says to take out the motherboard.... I forgot my case has an opening in the back lol... so I disconnected everything took out the 8 screws and then it wouldn’t come off!, I guess it is really stuck in the outside connections panel, anyway I didn’t want to put too much force, when suddenly I realized I could take the cases side off and it had a convenient hole for the cpu... I think noctuas instructions should mention that its likely the case has an opening and you don’t need to take the whole motherboard out...
The 1070 ti works really well with my setup, now the 2500K is at 52C max under load while before it was 72C, huge difference, going to try to OC to 4.0 first and maybe later try 4.2.
