[Req] Problem with triple channel memory and 4 slots
SaeedTJ
Hello All I have this problem:
The MoBo is ASUS P7P55D-E and CPU is i7-870 and there are just 4 slots on my MoBo while the RAM is XMS3 (3x2GB) 1.65v and Tri-channel 🙁
what should I do to have the best mode? can i change the binary of MoBo slots? if yes, How? if no, so? ;(((
tnx for your nice forum (wonderful)
Ah looks like it does support Flex, so then you have the 4 in dual and the odd 2 in single, short of going 4x2GB or 2x4GB this is prob about the best you'll get, often folks will move the CR to 1T for an added boost, which you have already done (very good ! ), could try up to 1600 and add a little DRAM voltage to try and stabilize, that may require dropping CR to 2T
i know what you say but you can see my req in ths picture, MoBo uses dual channel first and then if the third memory is needed it uses the third one :| ... take a look:
