edward78 Distinguished Jan 31, 2010 443 1 18,795 Apr 9, 2024 #1 So Motherdourd back I/O plates are 2ish inches & so are dual slot GPUs right? I am wanting to get a OG Xbox case & fit a sandwich style PC in it.
Lutfij Titan Moderator Oct 7, 2009 61,795 6,983 178,440 Apr 9, 2024 #2 Bad idea; View: https://youtu.be/llnxEC-im5M Upvote 0 Downvote
H hotaru.hino Glorious Sep 1, 2020 9,805 3,567 46,090 Apr 10, 2024 #3 Keep in mind that the original Xbox's power consumption was something like 100W. Unless you intend on poking a ton of holes in the case for ventilation or you're using low power parts, you're going to be thermal throttling the poor parts in there. Upvote 0 Downvote
