request timed out problem
narutodluffy
49
hi I get drops when im browsing or playing online game such as league of legends...it really annoys me while playing online games ...instead I use mobile tethering via usb , its fine with my mobile...this is happening with 2 of my laptops ...i also tried upgrading my window 7 to window 10...the isp helpers visited so many times...they changed the ont and tried router etc too, but nothing helped...reinstalling drivers...installed windows updates...its okay via LAN ....plz help me
I use command ' ping 192.168.100.1 -t '
Reply from 192.168.100.1: bytes=32 time=1ms TTL=64
Reply from 192.168.100.1: bytes=32 time=24ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
after typing 'ipconfig /all' I get this...
C:\Users\Narutodluffy>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Narutodluffy-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 78-2B-CB-D3-C2-BE
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 1E-55-F9-13-B6-D5
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 5E-55-F9-13-B6-D5
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Dell Wireless 1702 802.11b/g/n
Physical Address. . . . . . . . . : EC-55-F9-13-B6-D5
Link-local IPv6 Address . . . . . : fe80::b0f3:3e67:abf:46de%19(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.100.4(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, January 19, 2017 9:07:51 PM
Lease Expires . . . . . . . . . . : Friday, January 20, 2017 1:23:46 AM
Default Gateway . . . . . . . . . : fe80::1%19
192.168.100.1
DHCP Server . . . . . . . . . . . : 192.168.100.1
DHCPv6 IAID . . . . . . . . . . . : 502027769
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-A9-44-BF-78-2B-CB-D3-C2-BE
DNS Servers . . . . . . . . . . . : 192.168.100.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection 3:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #3
Physical Address. . . . . . . . . : EC-55-F9-13-B6-D6
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:2078:1f39:9acd:b6f6(Preferred)
Link-local IPv6 Address . . . . . : fe80::2078:1f39:9acd:b6f6%7(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 117440512
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Reusable ISATAP Interface {C8F82C8C-E2C7-4FBF-9E40-E4D1C231A432}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
I would really appreciate it if someone helps me
srry I don't know much , but we don't use router (device) ...only the ont main device.....they brought a router device and checked the ping thru that ...but had the same problem
also about the restart , yes I havent checked properly about that but sometimes I'm having lesser problems....the time interval between the request timeout is more
-they brought a router device and checked the ping thru that ...but had the same problem
They are your ISP ?
Are you using router or not ?
Whats the current structure, cable directly goes into your computer and no other components involved before that ?
yeah they're isp .....with direct lan cable the ping is perfectly fine, but prob when wirelessand yes 192.168.100.1 is my gateway ip ....idk if you call that router
I use laptop (wifi) to connect to my Nayatel (isp) .....but when I use usb tethering while mobile is connected to Nayatel , it works fine.....the problem is only when I use laptop wifi
I connected the same laptop wifi to another isp (ptcl) it worked alright, but this is when I went to another city...does overlapping cause request timed out error?
Mobile data also gives me the same problem...but when I used mobile hotspot in another city ...it worked perfectly fine
srry I don't get what you mean by router....is it the main device that provides the wifi access?coz that's the only device...also they recently changed it and put up a new one.....and this whole internet was setup ,like a year ago
