In case the original is still "invisible", here is a copy/paste
***Please don't move or delete this***
Anyways, I'm looking to upgrade my Dell Optiplex 390 SFF. Below are the following specifications:
MOBO: 0F6X5P A00
Chipset: Sandy Bridge Rev 09
Southbridge: H61 Rev B2
Bios Version: A14
Socket 1155 LGA
Supports DDR3 RAM at 1333 MHz
Supports 1 3.5" Hard Drive SATA 2.0
I'm looking to upgrade to the following:
1x 2 TB 3.5" Hard Drive 7200
2x 8 GB RAM Sticks at 1,600 MHz (which I assume will downgrade to 1,333 MHz, but I believe they should be compatible, right?)
1x Intel Core i7 2600
This should be compatible with the socket. I have also updated the BIOS to the most recent version. So it should technically work. Yes, I know that the most recent processor that Dell has tested was the i5 2400, but others that they haven't tested have worked.
If the i7 2600 doesn't work than the following will have to do
1x Intel Core i5 2500k or Intel Core i5 2400
1x Geforce 1030 2 GB, Geforce 750 TI 2 GB, or Geforce 1050 TI 4 GB
Any of the above video cards are fine with me.
Is there any particular reason that any of the components above would not be compatible with the MOBO? That is all the information that I can think of from the top of my head, if there is anything that I left out, please let me know.
MOBO: 0F6X5P A00
Bios Version: A14
Socket 1155 LGA
