Require relatively cheap monitor advice
hogfather 2010
24
My monitor is definitely on the way out and I require a replacement. However, many of the suggestions on this board and elsewhere I haven't been able to find on store websites in my region. I've selected 2 potential purchases but I have no idea if they are good price/quality wise.
I've included the links to said websites so that you can browse the stores for better alternatives if my selection seems weak.
http://www.codima.be/product/2583/aoc-22-e2250swda-led-169-1920x1080-5ms-dsubdvi-4038986121439.aspx
AOC 22" E2250SWDA LED 16:9 1920x1080 5ms DSUB/DVI
€ 125,00
54.61 cm (21.5 ") LED, 1920 x 1080, DCR 20000000:1, 250 cd/m2, 5ms, DVI, VGA, 23W, Black
AOC e2250Swda. Display: 546.1 mm (21.5 "), 5 ms, 250 cd/m², 1920 x 1080 pixels, LED, 20000000:1, 16.77 M, Unspecified, 1920 x 1080 (HD 1080). Colour: Black. Audio: 2 pcs. Ergonomics: 75 x 75 mm. Energy management: 23 W, 0.5 W. Weight & dimensions: 18 mm, 18 mm. Certificates: CE, cCSAus, TUV/S, RoHS, EPA 5.0, Win7, China RoHS
http://aios.be/productendetail.cfm?p=4934&s=139
Samsung S22B300B (21.5' - LED - 1920x1080 - 5ms - 1000:1 - DVI - VGA)
€ 129.91
Samsung SyncMaster S22A300B - LCD display - TFT - 21.5'
21.5' - widescreen
Max Resolution
1920 x 1080
51.2 cm x 19.7 cm x 38.5 cm - with stand
Image Brightness
250 cd/m2
Image Contrast Ratio
1000:1 / 5000000:1 (dynamic)
are these good price/quality ratio wise? Also, which between these would be best?
If pressed, I may up my max price to something around €140, but I'd rather not.
Also, I'll be using this monitor for gaming as well as general work stuff (mostly working with text documents).
The only real difference between them that I can see is that the AOC has a better contrast ratio. That said Samsung is going to be higher quality, so less likely you are going to have problems with it down the line.
