T Taga Reputable Jun 26, 2014 10 0 4,510 Sep 6, 2018 #1 Hi Guys What is the required Power Supply unit for a CORE 2 DUO? or for a CORE I5 CPU? Kind Regards Taga
Solution zebarjadi.raouf Sep 6, 2018 Taga : Hi Guys What is the required Power Supply unit for a CORE 2 DUO? or for a CORE I5 CPU? Kind Regards Taga Depends on the specific model you're looking for but 300W should definitely work without dedicated GPU card.
zebarjadi.raouf Commendable Jul 10, 2018 862 3 1,310 Sep 6, 2018 Solution #2 Taga : Hi Guys What is the required Power Supply unit for a CORE 2 DUO? or for a CORE I5 CPU? Kind Regards Taga Depends on the specific model you're looking for but 300W should definitely work without dedicated GPU card. Upvote 0 Downvote Solution
