Hello, i was looking into cooling my NZXT H440 case and i found a build named the reaper. However, i checked the pump he used which is called "EK-XRES 140 D5 Vario" but it is discontinued. Anybody got a pump which is the same size, capacity and around the same price?
Also, if possible i need a mount for this to replace the "UN 120mm Reservoir Holder" but please just tell me if i need to change it or not
Thanks,
Tom
NOTE: I couldn't find the Cooling Forum, please move it if you can.
Thanks,
Tom
