Question Reset BIOS without CMOS battery
tomilache
Commendable
Nov 6, 2020
8
So im in a really specific situation here, i basically just turned UEFI boot on, and it has no display. I wouldve just removed the battery, or short circuit the RESET pins, but sadly, both of those are under my gpu, which covers 1/3 of the motherboard, and that i cant remove because its being blocked by a part of my case. I dont even know how the guys got it in there.
TL DR: Need to reset bios without short circuitting the pins or removing the CMOS battery.
which motherboard is it?
Which case?
if the motherboard has no reset button, you will have to use the CMOS jumper or battery removed
remove the drives or cables of your system, power on, eventually the BIOS can be reached to alter the settings again
try booting with a bootable USB flash drive
Which case?
I have a
0GY6Y8. The cmos jumper i think is also under the GPU. If you meant unplugging the power, i did. I unplugged it and left the pc for 12 hours, still nothing. The case is from a optiplex 7010 tower i7 3770.
nope, he said tower, not sff
Saw it, but why should the GPU then be covered by anything?
The gpu is behind the metal part of the case, here's somehow a picture.https://media.discordapp.net/attachments/1133471464398540820/1159116245111672892/Picsart_23-10-04_16-13-25-222.jpg?ex=651eb6a0&is=651d6520&hm=5a9296522cc539a3e44cf4f7f548ab833501ec603cd66868e7dcf788fd886aa9&
