Dylan_K_4 :
bailojustin :
Change your boot from uefi to legacy, if your OS is legacy which most likely it was installed legacy, Go into your bios, Disable UEFI boot, Choose to boot from LEGACY.
There doesn't appear to be legacy option. I built the PC if that helps. The motherboard is ASROCK H97 Pro4... thanks for trying though
when booting, try to boot to the boot menu, pressing f10 or whatever command it is, and select a boot that does not include uefi.
this could also be your USB drivers, and usb 3.1 drivers.
Try unplugging and plugging them back in when its fully booted.
if it comes down to it, use a ps2 mouse to install the chipset drivers or your usb drivers to get your mouse and keyboard working properly, or make sure they are plugged into a 2.0 slot, black, rather then then blue 3.0
