Reset PC is bugged/laggy and causes problems.
Rio_2_
31
My PC had little to minor issues before the reset and the problems werent the reason for me resetting my pc.
Specs:
gtx 1080
i7-4770k
16gb ram
msi z87-g41
250gb SSD
some random HDD's
What's basically going on is: My FPS in games is fine (League of Legends) but the audio in the game is going nuts (Goes at 3x speed is choppy and has a static sound) which makes it unplayable.
If i open a window from my Task bar (while watching a video for example) The video laggs until the window i clicked on opens. (Another example would be my Discord audio stopping while opening something from my task bar)
Some programms just lag for no reason and are pretty unresponsive although a heavy load like a videogame works fine(besides the games audio).
Other then ingame audio my audio works fine (on videos and spotify)
What i tried to fix this -
Restarted my pc (alot).
reinstalled GPU and sound drivers.
Here are the first steps to take when trying to solve many hardware problems. If you have already tried these steps we can move along to more advanced solutions.
If there are any you have NOT done, it would be advisable to do so if for no other reason than to be able to say you've already done it and eliminate that possibility.
First, make sure your motherboard has the MOST recent BIOS version installed. If it does not, then update. This solves a high number of issues even in cases where the release that is newer than yours makes no mention of improving graphics card or other hardware compatibility. They do not list every change they have made when they post a new BIOS release.
Second, go to the product page for your motherboard on the manufacturer website. Download and install the latest driver versions for the chipset, storage controllers, audio and network adapters. Do not skip installing a newer driver just because you think it is not relevant to the problem you are having. The drivers for one device can often affect ALL other devices and a questionable driver release can cause instability in the OS itself. They don't release new drivers just for fun. If there is a new driver release for a component, there is a good reason for it. The same goes for BIOS updates.
IF you have other hardware installed or attached to the system that are not a part of the systems covered by the motherboard drivers, then go to the support page for THAT component and check to see if there are newer drivers available for that as well. If there are, install them.
The last thing we want to look at, for now anyhow, is the graphics card drivers. Regardless of whether you "already installed the newest drivers" for your graphics card or not, it is OFTEN a good idea to do a CLEAN install of the graphics card drivers. Just installing over the old drivers OR trying to use what Nvidia and AMD consider a clean install is not good enough and does not usually give the same result as using the Display Driver Uninstaller utility. This has a very high success rate and is always worth a shot.
If you have had both Nvidia and AMD cards installed at any point on that operating system then you will want to run the DDU twice. Once for the old card drivers (ie, Nvidia or AMD) and again for the currently installed graphics card drivers (ie, AMD or Nvidia). So if you had an Nvidia card at some point in the past, run it first for Nvidia and then after that is complete, run it again for AMD if you currently have an AMD card installed.
Here are the full instructions on running the Display driver uninstaller and CLEAN installing new drivers.
*Graphics card CLEAN install tutorial using the DDU*
And if after doing all that the problem is no better then I'd highly recommend doing a CLEAN install of the OS rather than a reset. A reset rarely works well and generally if you are resetting to the factory partition, that's a process we tend to frown on because you end up putting all the preloaded garbage and bloatware that was probably responsible for your system never working as streamlined as it should have from the start OR putting back on an installation that YOU did in the beginning that perhaps wasn't actually a clean install to begin.
Plus, it puts you back on an older build version, if you are running Windows 10, which means you need to not only regress to an older build version that includes things that might have been buggy all along but also leaves you with the need to once again update past all the spring, fall and incremental updates that have been released since the last time a clean install of the operating system was done. That actually sort of applies to any version of Windows, but even more so with Windows 10.
So in light of that, and a lot of other potential issues that are rarely even recognized but which exist such as not doing the RIGHT kind of installation, meaning a legacy install rather than a full UEFI instalation using a GPT partition rather than a legacy MBR type install, I'd recommend doing this:
Windows 10 Clean install tutorial
Okay i guess i ment a Clean OS install while saying it was a reset.
I also used DDU to reinstall my drivers when i said ive ''reinstalled'' them.
Now what ive done is ANOTHER clean install of my OS and downloaded the newer versions of my lan, Audio, and chipset drivers from https://us.msi.com/Motherboard/support/Z87-G41-PC-Mate.html#down-driver
The problem with opening things from my taskbar lagging videos/discord is still a happening.
Another thing i noticed is while opening my Geforce overlay that my desktop went all black and the only thing showing was the Geforce Experience overlay. Which makes me think my GPU went bad. But in that point iam kind of in denial since its a very new gpu i dont even own it 3 months and it worked fine up until the Clean os installation.
Okay my second Clean OS installation went fine until I hooked up my second monitor which caused huge lag in games/benchmarks. My main monitor is 144HZ and my second is only 60 but that didnt cause any problems before the clean OS, maybe i fixed it somehow back in the day but i dont remember how since its quite the time ago.
