This morning I was tinkering around with some BIOS settings (not a good idea if you're 70% aware of what you're doing). After hitting f10 to save and exit, my computer immediately shut down, then tried re-booting itself. My video card did not pick up a signal. I tried resetting the CMOS with the jumper. Nothing happened. I tried taking out the motherboard battery for 5 minutes, nothing was fixed. I'm going to take out the mobo battery for 1 hour and see if anything happens there.
I took out the manual for my motherboard and looked up the LED errors because I noticed that 2 LEDs were out. The manual states that if they are off, there is an "Abnormal: CPU/Chipset" error.
I'm still getting a blank screen. My monitor isn't recognizing the computer signal and just sits at a black screen. Thanks for your help.
Here are my specs:
Windows 7 64 bit home premium
Biostar TX5E CFX-SLI Motherboard
i3 540 Clarksdale
2 x 2gb Corsair RAM (1333mhz)
2TB Wester Digital SATA
HIS Radeon 4760 HD
Here are my specs:
i3 540 Clarksdale
HIS Radeon 4760 HD
