Resolution 1920x1080 and 1440x900 and LCD TFT & LED.
benjy30
My LG flatron 19inch lcd tft 1440x900 monitor has died. I tried another lg but 22 inch led 1920x1080 and i couldnt adjust to the text being so small. Even after making windows 7 increase text and icon size, webpages had to be increased in size also creating distortion. Plus i found the screen display smokey looking. All i want is another of what i had. Can you help? Many thanks.
If you really cannot adjust to 1080p and absolutely do not want to run a lower resolution on your current screen, this is a the 19", 1440x900 version of the 1080p monitor I use. Fantastic color recreation. You will find that this looks far better than your old TFT display.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236203
HOWEVER, I went from a 16" screen at 1366x768 to a 19" at 1440x900 to a 22" at 1080p, then upgraded to a 24". After getting used to the smaller text I would NEVER go back to a smaller screen resolution, you can do so much more when you can fit more on the screen.
