Resolution Issue - HELP
FormidableRed
36
Hello.. So last night I installed the new 398.82 driver for my GTX 1060 and while it was installing, the resolution of my display changed to be native at 1024x768, and I couldn't change it to anything else..
So I assumed the drivers hadn't installed correctly, so I reinstalled them.. Same issue.
I then installed the previous version of drivers, as that was working before the update? The issue was still the same.
I then used a different monitor (the exact same, just a different one) and the issue was sorted? But the one it works on has some dead pixels so I don't actually wanna use it. Has anyone had this issue and know of a fix/stuff I could try to get it working?
Thanks
