Resolution will not pass 1400x1050
guitars198
8
Hi! Sorry if this is the wrong thread; I wasn't entirely sure where to post this.
So I have a problem... my computer and gateway monitor normally run at 1920x1080. Today when i turned on my pc, my resolution was set to 800x600 and it WILL NOT go past 1400x1050 and there is no option to go past it. Also, when i go to control panel and screen resolution, the display only says (Default Monitor) ON, when normally it says Gateway or something like that.
any help?
Thanks!
And i can give more details if needed.
So I checked device managers, and my ATI Radeon 5800 Series has a yellow triangle with an exclamation mark in it.
Then it says in the Device status " Windows cannot initialize the device driver for this hardware. (Code 37)"
Update:
Went into the control panel to troubleshooting hardware and devices. It found the same error as before and it is attempting to reinstall the drivers.
Problems found:
LDDM Graphics subsystem is disabled. NOT FIXED (red x)
Hardware changes might not have been detected. DETECTED (yellow triangle)
Ati Radeon HD 5800 Series has a driver problem. FIXED (green checkmark).
i still cannot go above 1400x1050 though..
