Question Restart, sleep mode or second boot will trigger display, audio and mouse stutter ?
Jun 1, 2023
6
hey guys i need help please ,My whole pc stutter both display and audio(it has a robotic sound buzzing thingy) even the mouse cursor is teleporting every second and sometimes the mouse cursor strangely pulling to the left side of screen but im sure my mouse is not damage because i try different mouse ,The weird thing is when i disable the family controller drivers the mouse pulling thingy is gone,but all my drivers is in the latest version. ,The things it will triggered the stutter when i put my pc into sleep mode or restart the pc ,also second boot when i shutdown the pc and turn it on again after 2 hours ,the only thing it will fix after many times of restart ,this means it has a good boot or bad boot after 10 minutes without any stutter it will continue to run smoothly without any issue.
PC SPECS
Installed Physical Memory (RAM) 16.0 GB( 2*8) spectrix D50 (3600MHz)
SSD 480GB kingbank SATA
liquid cooler -gammaxx l240 deep cool
power supply-corsair 650 watts
Processor AMD Ryzen 5 5600G with Radeon Graphics, 3901 Mhz, 6 Core(s), 12 Logical Processor(s)
mobo- GIGABYTE B550M DS3H AC (built in wifi)
OS Name Microsoft Windows 11 Pro
Version 10.0.22621 Build 22621
OS Manufacturer Microsoft Corporation
System Manufacturer Gigabyte Technology Co., Ltd.
System Type x64-based PC
System SKU Default string
BIOS Version/Date American Megatrends International, LLC. F2b, 3/23/2023
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Product B550M DS3H AC
BaseBoard Version x.x
Platform Role Desktop
Secure Boot State On
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Total Physical Memory 15.4 GB
Available Physical Memory 5.68 GB
Total Virtual Memory 20.1 GB
Available Virtual Memory 3.28 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Windows Defender Application Control policy Enforced
Windows Defender Application Control user mode policy Off
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
USING DUAL MONITOR 27 inch both 165hz but i set it both to 120hz
(THINGS I TRIED)
-clean reinstall windows 10 pro
-clean reinstall graphics driver using DDU
-reinstall all drivers from manufacturer site
-reset cmos
-update to latest version of bios
-change different monitor cables
-change mouse
-ram reseat
-cinebench for cpu it has a decent multi and single core scores
Jun 1, 2023
6
compare the gpu mhz before and after a restart/sleep
I already compare the mhz but it seems fine there's no difference.when i disable Realtek PCIe GbE Family Controller driver the stutter is gone .but the weird thing is i dont use Ethernet cable,i use wireless wifi.i tried disable on board lan in bios ,still happening ,i tried uninstall family controller driver and disable automatic driver installation,but still happening.do you thing this problem more on drivers conflict than hardware?
Nice Nicer
Commendable
May 24, 2021
88
Seems as If there is something wrong with your RAM configuration, or do i misinterprete these numbers :
My Tip :
Try a different kit of RAM If you have one, try one stick at a time and maybe exchange them.
PC SPECS
SMBIOS Version 3.3
BIOS Mode UEFI
(THINGS I TRIED)
-reset cmos
-change mouse
-ram reseat
Do you have Virtualization turned on in your BIOS? With many computers turning it on results in the system memory being totally cleared during a reboot.
