I had to replace the hard drive on a Toshiba Satellite A505 Laptop. No problem, I created the restore CD's from my Toshiba laptop when it was new. To minimize any problems, I purchased a Toshiba L200 Hard Drive to replace the Toshiba HDD2H21 that failed. Using my created CD's, I went through the restore process. I was never prompted for disks 4 or 5 but the computer displayed the message "restore was successful". Now for the problems:
1. Both the wired and wireless NICs say the driver is not digitally signed. By using the option under F8 to disable the signature checking, I was able to get on the internet and at least get the wired NIC working but not the wireless or any of the Ricoh components. I have tried to download the latest drivers from the Toshiba website but no luck.
2. I cannot get any windows updates to run, not individually, not using troubleshooting, nothing. I keep getting an error message that "Windows Update cannot currently check for updates, because the service is not running. You may need to restart your computer." I have restarted my computer, multiple times. When I go into services, it does show that both BITS and Windows Update are running. I have deleted the 'Software Distribution' folder and still nothing works.
I even tried to call Toshiba. I know the computer is out of warranty but the hard drive isn't
. They weren't buying that and they want to sell my a one time advanced service for $99. I refuse to pay that. They told me the drivers had to be installed individually but the created recovery CD's do not allow that option. I DID order their recovery CD's for $29.99 but I won't receive them for 7-10 business days.
Is there something else I can try? I appreciate any advice you can give me.
Thank you!
Thank you!
