Retailplus wireless N USB adapter
aa_toro_e
4
Is there a driver for Windows 7? got this adapter, never used it, now trying to install for windows 7 and not working.
most of the time if you plug it in, while keeping internet wire in you can get windows to install a generic driver.
click start
right-click on "computer"
click on manage
then on "device manager"
then on "network devices"
right-click on the one with the yellow symbol next to it and select "update driver software"
it might apear somewhere else but it will have a yellow symbol next to it. (if not then click on "action" at top left and scan for hardware changes
the above steps will only work if your pc can see it, if you plug it in and nothing happens then try a different usb port as it might be a faulty port
It doesn't work, those are drivers for Win 2000, Vista, XP. Do not work for Win 7. I wonder if there is a fix at all. Saw an old posting from ekfsks that he found a fix, but didnt specify.
you can use vista drivers on win7
