Retina monitor
velocci
1,028
16
19,285
hi all, are there any monitors with retina display? if not, do you think we will get them soon? i'm using a very old 19" monitor and would like to get a new one and hoping to get a retina display. thanks
I think that since the rules are strict they cant or the will get banned or something🙁 My bud did that and got banned from posting it from ebay 🙁
Huh? so many products are linked and model numbers given out on this site, in almost every thread... I don't see how this is any different.
I went to http://www.auria.com/categories and found no mention of any monitors by this company. Can you buy this in Canada?
BigMack70, don't mean to hijack this thread, but it sounds like you recommend that Auria. I've been looking at getting one at the local MC. Is it true BIOS doesn't show with DVI and you can't adjust colors with Displayport? I've been reading about it and found some people describing little quirks like this.
7970 lightning doesn't have dl-dvi? TIL. Do you use minidp>dp or do your cards not need that adapter? I barely ever play fps games, unless borderlands counts, so I'm not too concerned about that. I have a cheaper acer 23" 1920x1080 with terrible backlight bleed, so I'm sure the Auria would be better all around. Thanks.
My 7870 came with a minidp>dp adapter so I just need a normal dp cable or if I want to use dvi I will need an hdmi>dvi adapter so I can have both monitors hooked up. I know I will need to upgrade my gpu, but I'll wait for the next series to do that.
The nearest you will come is a IPS panel. Most under 27" will only be upto 1080.
Here is a Nice Asus 23" for only $184 (175 after $10MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288
Asus $150 + $9 shiping (BUT ONLY 21.5"): http://www.newegg.com/Product/Product.aspx?Item=N82E16824236205
** My choice) Asus $209 (after $20 MIR) + $9 shipping 24.1": http://www.newegg.com/Product/Product.aspx?Item=N82E16824236262
Full listing of IPS Monitors @ Newegg Also some sub $400 27" : http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100006652&isNodeId=1&Description=IPS&x=22&y=18
so you saying this monitor is not good for professional photo editing? I'm not a pro photographer, but its my hobby and this is why i want a high resolution monitor.
One more comment on this:
I notice a lot of higher resolution 27" displays. But higher resolution is not the same as higher ppi.
I am hoping to get something which has a high resolution but does not deliver more text on the screen, but instead delivers higher crispness to the text.
Kind of like how the Retina MB Pro delivers only the earlier 1440x900 actual pixels, and in the process keeps text size the same as earlier MB Pros but far more crisp text and icons.
Any such monitor available? Or can the higher resolution 27" monitors be used like the Retina display on MB Pro to increase crispness as opposed to increasing the amount of text on the screen?
Thanks!
I currently use a circa 2009 MB Pro and have been considering moving to the newer one. So in your knowledge, will the new MB Pro increase PPI any on the higher resolution 27" displays. I guess not - considering that the resolution of the WQHD 27" displays do not appear to be multiples of any typical resolutions...
I bought a Shimian 2560x1440 from a trusted buyer I found in the these forums. I bought it straight from Korea. Its flawless and stunning to play games on. Its an IPS display made by LG. They built them for Apple for the $1000 Thunderbolt display. Its a stripped down version with no built in scaler (any good GPU handles it anyway) so it has VERY low latency. Best $265 I have ever spent.
Im LOVING mine too. Got a Shimian and it really is amazing. Ive been gaming for many years and I jumped off something high in Borderlands 2 when I first got it and actually got a falling feeling in my gut for a sec. VERY immersive. The detail in serious games is incredible. Examples: Crysis 2, Skyrim. I highly recommend them as long as you purchase safely.
