Archived from groups: microsoft.public.win2000.dns (
More info?)
ok, I setup the new zone as you suggested and the only
thing I am not 100% sure about is what the FQ host
name of my mail server is. Is is mail.insurors.com or
iot5.insurorsindemnity.com? How do I find out. Then in
regards to forwarding the ports, where am I supposed to do
that from? my firewall, router, ? thanks
>-----Original Message-----
>In news:2281701c45d40$42490bb0$a401280a@phx.gbl,
>anonymous@discussions.microsoft.com
<anonymous@discussions.microsoft.com>
>posted a question
>Then Kevin replied below:
>> ok, I talked to SBC this morning and they have now
>> delgated control to me. The switched it from
>> NS67.Worldnic.com to my dns server 66.140.116.4. SBC
also
>> had me create a new A record from my netsol DNS
management
>> area call ns.insurors.com which is forwarded to
>> 66.140.116.4. So SBC is pushing everything to
>> ns.insurors.com which is pushing to 66.140.116.4 which
is
>> my dns server. So I created a new reverse zone
>> 66.140.116.x subnet and created ptr record in there, ip
>> number 5, and still nothing. This is wearing me out.
Any
>> other suggestions?
>You have a couple of problems.
>1. When I tried to run a lookup against your DNS server
at 66.140.116.4 I
>can't get an answer. Make sure you forward port 53 UDP
and TCP to your DNS
>server from this IP.
>2. Your reverse lookup zone is misnamed if what you
stated is correct.
>Delete that zone and recreate the zone like this.
>New standard primary reverse lookup zone, wehn you click
next to enter
>either the SubNet Id or zone name you must select select
zone name, name the
>zone "0.116.140.66.in-addr.arpa." (without the quotes)
next, then finish.
>Now create the PTR, IP # 4 with ns.insurors.com and IP #
5 with the FQ host
>name of your mail server.
>When you create a delegated Reverse lookup zone you have
to create the zone
>by the name it is delegated to. The Zone name your IP is
delegated to is
>"0.116.140.66.in-addr.arpa." Put your PTRs in that zone.
Oh, to see the zone
>name in the GUI in the View menu select "Advanced"
>You can see this in the www.dnsstuff.com when you use the
reverse lookup
>tool.
>Asking ns1.swbell.net. for 4.116.140.66.in-addr.arpa PTR
record: Got CNAME
>referral to ns.insurors.com. (zone 4.0.116.140.66.in-
addr.arpa.)
>Asking ns.insurors.com. for 4.0.116.140.66.in-addr.arpa.
PTR record: Timed
>out. Trying again.
>Asking 4.116.140.66.in-addr.arpa. for 4.0.116.140.66.in-
addr.arpa. PTR
>record: Error: Couldn't resolve DNS server name/IP
>[4.116.140.66.in-addr.arpa][11001].
>Best regards,
>Kevin D4 Dad Goodknecht Sr. [MVP]
>Hope This Helps
>When responding to posts, please "Reply to Group" via
your
>newsreader so that others may learn and benefit from your
issue.
>To respond directly to me remove the nospam. from my
email.
> http://www.lonestaramerica.com/
>Use Outlook Express?... Get OE_Quotefix:
>It will strip signature out and more
> http://home.in.tum.de/~jain/software/oe-quotefix/
>Keep a back up of your OE settings and folders with
>OEBackup:
http://www.oehelp.com/OEBackup/Default.aspx
