Review my ~$500 small office build
sonarzero
Approximate Purchase Date: Next week or so
Budget Range: under $500 after rebate, cheaper if possible
System Usage from Most to Least Important: Surfing the web, word processing & spreadsheets, some flip video making/editing
Parts Not Required: keyboard, mouse, speakers, monitor
Preferred Website(s) for Parts: newegg.com, amazon.com
Country of Origin: USA
Parts Preferences: no preferences, quality/reliable
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: not sure
Additional Comments:
Hello there. I'm looking to build a few PC's for a small non-profit office mainly for web access and office programs.
After checking some of the other builds on the forum here's what I've got (feedback, suggestions, combo deals welcome):
PSU: CORSAIR Builder Series CX430 V2 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
MB: GIGABYTE GA-A55M-S2V FM1 AMD A55 (Hudson D2) Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128528
APU: AMD A8-3850 Llano 2.9GHz 4MB L2 Cache Socket FM1 100W Quad-Core Desktop APU AD3850WNGXBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103942
RAM: ? DDR3- 1600 or 1866? With 64-bit OS I'm guessing you need 4GB min, but with APU probably 1GB for graphics so I need more like 8GB?
HD: Western Digital Caviar Blue WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
DVD: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Case: ?
Recommendations on wireless cards would be helpful as well.
Thanks!
cutebeans
2,809
150
Get 4gb right now. If it's lacking get another one later.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231313
Get this 1tb $71 (Cheapest)
http://www.amazon.com/Seagate-Barracuda-7200-12-Internal-
ST31000524AS/dp/B004IZN3YI/ref=sr_1_1?ie=UTF8&qid=1320416176&sr=8-1
Pick one:
PCIe wireless card
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704059
or
USB wireless card
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704032
Cheap case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
sonarzero
Thanks for the suggestions. Looks like I'm pretty much ready to go at this point, except newegg appears to be out of the A8-3859
That's too bad about Thailand and the hard drive prices :(
Similar threads
