APPROXIMATE PURCHASE DATE: 1-2 weeks
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Web browsing (90%), CD burning, IPOD, GPS Software,
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, mwave, tigerdirect
PARTS PREFERENCES: Intel CPU
OVERCLOCKING: No
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1024x768,
Here's what I put together based on Proximon's recommendations. It's probably overkill but I'm leaning for 6GB memory. I could probably go with integrated graphics. Does the P45 chipset come w/ on board graphics? Here's my parts list from Newegg:
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail $134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
Intel Core 2 Duo E7400 Wolfdale 2.8GHz 3MB L2 Cache LGA 775 65W Dual-Core Processor - Retail 119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
HIS H485FN512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Reta 109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161259
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6GK - Retail $114.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
NZXT TEMPEST Crafted Series CS-NT-TEM-B Black Steel / Plastic ATX Mid Tower Computer Case - Retail $87.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146047
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM 74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders w/ Tech Guarantee - OEM 109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116677
SAMSUNG 22X DVD±R DVD Burner Black IDE Model SH-S222A - OEM $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
OVERCLOCKING: No
