I just overclocked my Q6600 on my Evga 780i and Tuniq tower 120 cpu cooler. I decided to shoot for 3.2Ghz 8x400. I set the bios to expert for memory and then selected unlinked and set my Gskill F2-8000CL5D-4GBPQ to 800mhz and the bios then automatically changed my voltage from 1.85v to 2.1v and timings from 5-5-5-15 to 5-4-4-12. I am running Prime95 now and so far so good at 1.328v under load and 1.376 idle in cpu-z . This is with the cpu voltage in bios set at 1.40625. Temps are around 54c with the Tuniq tower fan on high. CPU FSB and nforce spp are set to auto and both are at 1.4v. How does this look? Did I do everything correctly? Would I be better off setting the FSB to 1424 for a 9x356 overlock? would I then set the memory to 712mhz? I am also confused about having a 1:1 divider which I read is best. Wouldn't that mean that with a 8x400 and 9x356 overlcock that the memory would be set to 356mhz and 400mhz respectively? I'm sure I'm missing something as that sounds way too slow for ddr2 1000mhz memory to be under clocked to. When I selected linked mode in the bios for a 1600mhz fsb it set my memory to 1400 which sounds way too high for 1000 mhz memory. I am unable to get a lower voltage stable, but I'm concerned this voltage might be a little high, as I plan on using this cpu for a long time. Which of the 3 voltages is the one I should be concerned with? Thanks for looking at this and giving me your input.
Would that be 1.3v in bios or in cpu-z? Is the difference between the two the vdrop? Do you think the voltage of my ram can be decreased also?
