G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I just wanted forwarn anyone who is considering the Ahanix "Extreme"
case.
http://www.ahanix.com/extreme.html
It is by far the worst case I have ever had the experience to use.
Its micro atx power supply is so under rated I can hardly hold a
simple session in windows 2000 no less use it for its intended
application. A +12V at 9Amps maximum power is an utterly worthless
PSU rail rating. Not in any way capable of an "Intel P4 and AMD
XP/MP Compatible" system as noted in the features portion of you
product description.
Also, the case fan has something in common with its name in that it
makes and EXTREME amount of noise. Other grips are the lack of
instructions on proper positioning for the thermal probes, improperly
de-burred edges (Like Razor Blades), poor ventilation, minimal
mounting depth of PCI I/O with respect to the optical drive bay, and
misrepresentation of the case in the gallery in a desktop position,
when it is only intended for tower application.
The only aspect of the case I appreciate is its appearance, which is
further depreciated by the fact that it is extremely susceptible to
scratching.
I am so disappointed with this case and its performance, I wanted to
make sure that no one else even consider buying it.
COMMENTS WELCOME.
BTW: I have no other experiences with Ahanix Products but
this has definitely tarnished my opinion of the brand.
case.
scratching.
COMMENTS WELCOME.
