Hey guys,
I've been lurking the past couple days and reading up on water cooling. I've been planning to build a new system and want to incorporate a water loop into it. I've read through the sticky but before ordering, I'd like to have the experts here give things a once over so I can feel confident that I'm not missing anything or making some other mistake. I'd be happy to listen to any advice on ways to cut down the cost of the system as well.
System details
Case: Phantom 630
GPU: 2x EVGA 780 GTX in SLI (hydro copper)
CPU: i5-4670K
Motherboard: ASUS Maximus VI Formula
Water Loop Details
I want to build a loop that cools the CPU and 2 GPUs. as such these are the components I'm planning to order.
CPU block: XSPC RayStorm Acetal
GPU block: Built-In (Apparently also sold separately)
Radiator: Phobya Xtreme 400mm
Reservoir: Alphacool Repack Dual 5.25" Acrylic Reservoir
Pump: Alphacool VPP655
Connectors: Bitspower Ultimate 3/8"x12/" compression fittings
Tubing: Primochill LRT (10 ft)
Coolant: Distilled water with killcoil
SLI Bridge: Bitspower SLI Multilink Adapter
The portion of the build I'm most unsure of is how to connect the SLI cards in the water cooling setup. I'm not sure if the bridge I pointed to will actually work or not. Can I drop that bridge entirely and route the tubing around? Would this affect the loop in any way?
For the radiator, I plan to mount it to the top of the case with 2x200mm fans pulling.
Thanks for the help.
System details
Case: Phantom 630
CPU: i5-4670K
Water Loop Details
