Question RGB cable plugged in or dangling in case?
Jan 15, 2021
36
I recently installed a Cooler Master Hyper 212 EVO RGB Black Edition, and I have all cables connected the proper way.
The rgb header is plugged in so that the arrow is pointing to the 12V pin on the motherboard's connector.
Still, when I boot up the rgb turns on for a few seconds and turns off again and I cannot control it once I am all logged in. But all other RGB and lighting that came WITH the PC is working fine
My pc is a prebuilt Lenovo and the RGB software for Lenovo does not recognise this. I am planning to buy a cooler master rgb controller soon, but until then I do not know what to do with the connection.
Do I leave it plugged in as it is right now, or should I unplug it and just tape it to the case out of the way of other components?
I am afraid of having it plugged out as I feel I could short and damage something as all wires in the circuit of the RGB fan are not connected (RGB cable).
At the same time I don't know if it is safe plugged in as it isn't being recognized by anything so that could be a problem?
Will doing either of them cause damage to my PC ?
Note: My PC runs smooth and CPU cooler fans run perfectly fine.
System:
i710700
RTX 2070 S
Legion 2x8GB 3000Hz RAM
Lenovo Stock Motherboard
FSP PSU 80+ Gold
Cooler: https://www.amazon.co.uk/gp/product/B07H9JL1P8/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1
RGB Header (Separate from mobo) : View: https://i.imgur.com/2OGEKhm.jpeg
