RGB case and sleeved PSU cables
Syl7r
Hello my friends,
Im building a new case and I wanted you to give me your opinion just for the aesthetic point of view.
With what color should I pair the sleeved cables of the PSU? With the towers color? The motherboard and the GPU color? Or it should be different?
The tower is the P400s with the tempered glass with white color on the outside and black on the interior.
The motherboard it with be black with rgb but the GPU is the MSI GAMING X which is mostly red... and thats why im a bit confused about the color of the cables. Firstly I was thinking to make them black and red or fully black to be sure lol.
I know this is mostly subjective but I would like to see how others see it.
Thank you very much for your time.
The color of custom sleeved power cables depends on your build theme.
For example, my Skylake build has black & red theme with ability for full RGB. In there, i replaced the stock black power cables with custom sleeved red power cables. While in my Haswell build, i went with black & blue theme with also an ability for full RGB and replaced the stock black power cables with custom sleeved blue power cables. Full specs with pics in my sig.
In your build, your case internals are mostly black while your GPU gives some touches of red. I'd go with red or black/red colored custom sleeved power cables to create black & red theme inside your case.
Though, if you'd have MSI Armor series GPU in there then i'd go with white or black/white...
Though, if you'd have MSI Armor series GPU in there then i'd go with white or black/white colored custom sleeved power cables for classy black & white theme which would also match the white exterior of your case.
