[SOLVED] RGB case fans
Dubkiss
74
Hello i own a mid tower case from Zalmar with 3x 120mm rgb fans, is there change to change color without any modules ? I download a z sync in hope i can change the colors but it didnt worked. All 3 fans are connected with Molex
if there is no RGB cable leading to a motherboard header than you have no way to control colors or patterns through software.
you should list the make & model of the fans in question.
if they came with the case they should be listed in the case product specifications on the manufacturer product page.
what is A Z Sync?
software provided by Zalmar or your motherboard manufacturer?
have never seen this tied to any motherboard LED control option.
what is A Z Sync?
https://www.zalman.com/EN/Product/P...99&searchCategory3=-99&searchKey=&searchWord= this is the case what i own
and z sync is a software providel by zalman, also my friend said to me i should try rgb fusion, and still cant control the colors of fans
