RGB Choice/Setup help
KanyeJ19
55
G'day all
I'm looking to trade out some crappy $9 fans that I've been using for a while with some RGB ones. Though I'm unsure of what brand to go with. I've been looking at the Deepcool RF/CF fans, CoolerMaster's MasterFan Pro Air Pressure RGB or Corsairs HD 120 fans. Don't know much about fans and setups for them so any help is appreciated! (Would've written down the Corsair LL 120s but its $139 AUD for a 3 pack and far too expensive to cover the top and front)
Case is a Cougar Panzer, with the following cooling specs:
Front: 3x 120mm or 2x 140mm
Top: 3x 120mm or 2x 140mm
Rear: 1x 120mm
Corsair's ecosystem is by far the most complete - they run the absolute gamut of RGB options. For some tips on the Corsair RGB setup, check out http://forum.corsair.com/v3/showthread.php?t=173880.
