Sep 11, 2021
Hi,
I'm french so please be indulgent with my english.
My question is : how can I control each RGB and ARGB connectors individually ?
I have one led strip plugged in one RGB connector, another led strip plugged in another one, and I have 2 Cooler Master MF120 RGB fans connected in serial mode plugged in my only one ARGB connector.
So every RGB and ARGB connectors are used. I also have 2 RGB Crucial DRAM, and RTX 3080 Ti Founders Edition which is RGB too.
My problem is that when I use Aura sync, I can't control them individually.
When I use Aura creator, it detects only my led strips and my DRAM; and if I want to control the led strips, changes will apply to both of my led strips whereas they are plugged on 2 differents connectors.
So I decided to try some other software and I found Open RGB as a good option.
With this one, I can control each of my led strips individually which is very good, but my Cooler Master fans on my ARGB connector are not detected by the software so they are turned off..
I also tried softwares like Jacknet and ICUE but these are useless when you dan't have any Corsair devices. Signal RGB is worse.
I'd like to find a way to control each connector individually, is this even possible ? Why Aura Creator is so bad ?
System specs:
Asus z490 TUF GAMING PLUS
Intel i7 10700k
RTX 3080 TI FE
2x8 3200 Mhz Crucial
1 To SAMSUNG SSD
500 Go SAMSUNG SSD
Cooler Master 750W
Corsair 750D Airflow case
Be Quiet Pure rock 4
ASUS PCE AC 88 WIFI card
3x Pure wings 120
2x Cooler Master MF120
1x Silent wing
