[SOLVED] RGB Fan Connectors
Aug 7, 2020
5
Hi im about to build my first pc, the motherboard im buying is a B450 AORUS ELITE and the case is a Carbide Spec Delta RGB. The problem is that i dont know where i should plug the RGB connectors that come with the fans (the RGB fans are provided with the case) since the mobo has a 3 pin connector and a 5 pin connector while the RGB connectors have a 4 pin connector.
1| The info is in your case and motherboard manual.
2| You should be getting a splitter with your chassis that plugs to the fans.
3| The splitter's breakouts connect to the fans.
4| The single end of the splitter connects to the motherboard.
5| The header on the motherboard will be LED_CPU which works with 12V RGB devices.
