System: CyberPowerPC Gamer Xtreme VR, Windows 10 (build 18363) Issue: The case lights work fine and I can turn them on/off with the remote control. But one odd thing: -I have the lights on and the computer goes to (or is put to) sleep (and the lights go off as expected during sleep) -I wake the computer, and when the computer wakes, the lights come on for 1-2 seconds but then shut off on their own. I can manually re-turn them back on with the remote but they should turn on and stay on after a wake on their own. The lights used to work normally (off during sleep, back on when wake). The fans are not affected and work as expected – only the lights exhibit this behavior. Have you seen this before – any ideas on what I can do to fix it. It’s not critical since the fans are not affected, just an interesting problem. Thank you! |
