Question RGB fan not detected
Apr 14, 2019
So i bought a coolermaster MF120L RGB fan and connected it to my mobo (Gigabyte b450 Aorus Elite) the fan is spinning and rgb working but i cant control the rgb , i tried downloading RGB fusion 2.0 but the fan isn't detected , maybe its something with the fan headers ?
Did you put the RGB cable in the right spot on the motherboard? If you put it on a main fan spot (like a system fan) then it would just power the default colour of the RGB. Or did you connect the fan directly to the PSU which means you have zero control over it?
