I've been having issues with getting my computer to POST for about a month. It seems like I've tried everything, so I'm posting here to see if it's something obvious I'm missing. I'll try to give as much information as I have in this post, some of it might not be relevant. Computer was built a year ago.
So as the title suggest when I press the power button all the RGB work and fans start spinning, BUT with a white debug LED. The RGB turning on is, Motherboard, CPU fan, RAM sticks, GPU and fans. ALL the fans are working, but while the RGB on the GPU works the fans are not spinning. I'll post a picture at the bottom of the post for reference.
SPECS:
Ryzen 7 3700x
ROG B450-f Gaming
Asus RTX 3070 Dual OC (bought in January)
2x 16gb Trident Z neo 3600mhz CL16
Samsung 970 evo plus
Corsair RM650x
For troubleshooting I've tried the following with no luck:
Cleaned PCIE lane and reseated GPU
Tried a different GPU (GTX 1060)
Reseated and booted with one RAM stick (tried both of them)
Secure all the PSU cables to the motherboard
Checked the standoffs
Unplugged power, holding the power button down, removed CMOS battery
Reset CMOS(?) jumper with a screwdriver
Inspected the CPU for physical damage (looks good)
Tried different inputs (HDMI, DP)
Tried four different monitors (same thing, no signal detected)
I'll try to give a description of the situation which made my system unable to post.
Firstly a situation that was weird, but not the one breaking the system; I moved and was driving with the computer in the back, GPU was out and I had bubble wrap in the system. This was a 20-hour drive. When I wanted to boot up the system again, I got the same issue I have now. Fans spinning and everything, but no post. I just restarted my PC a couple of times and it posted, which worked fine for about a month.
THEN I bought a new monitor, and when I originally plugged it in the same issue. This time I had to take the GPU out and back in again, and it worked. But after a 4 hour gaming session I opened Chrome and immidieatly got a blue screen. This was the last time the system posted.
Since then I've been troubleshooting and pulling my hair out, hence this post.
I hope someone can help me out on this.
PICTURE;
View: https://imgur.com/a/GXluJVE
SPECS:
Ryzen 7 3700x
ROG B450-f Gaming
Corsair RM650x
PICTURE;
