Question RGB Fans not working...
Jan 3, 2022
7
Hi, I have been working on my first pc build. As soon as I finished, I gave it a test run to see if everything was working. The fans were moving and the GPU rgb was on, but the rgb of the fans itself weren't working. The fans came with my case which is the Coolermaster Masterbox MB311L ARGB. Please get back to me soon.
Please list the specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis: Coolermaster Masterbox MB311L ARGB
OS:
Might want to also include images of how you tethered said ARGB controller to your motherboard/PSU. Did you get the in-line controller or the splitter alongside the case? Might want to elaborate on what you mean by the RGB not working.
Thanks for the welcome!
Update: 1 fan ARGB works, 1 doesn't
CPU: Ryzen 5 5600x
Motherboard: Gigabyte B550M DS3H AC AM4 AMD B550 SATA 6GB/s MICRO ATX AMD MOTHERBOARD
Ram: OLOy 32GB (16GBx2) 288-pin DDR4 SDRAM DDR4 3200 (PC4 25600) MODEL: MD4U083216BJDA
SSD: CRUCIAL P2 1000GB - CT500P1SSD8
GPU: ROG STRIX RTX 3060 LHR OC
PSU: EVGA 650 BQ 110-BQ-0650-V1 BRONZE 650W
OS: Not Installed
Pictures:
110 KB
102 KB
108 KB
118 KB
So what I meant by the ARGB not working is that the top fan's ARGB is lighting up, while the bottom one is not. (I only have 2 fans which are both in the front)
Hi, I have recently been building my first PC, and after finishing it I noticed that only 1 of the fans' lights were on. Here are my specs below:
CPU: Ryzen 5 5600x
OS: Not Installed
what fans exactly and how many?
how are they connected; directly to motherboard aRGB headers, to an aRGB hub, etc?
what are you using to control their LEDs; case front I/O button, remote or built-in controller, fan manufacturer software, motherboard control software, etc?
The fans are the default ones that came with my case (Coolermaster Masterbox MB311L ARGB). I have 2 fans that are both in the front. I have a small controller that I put on the inside of the case, and I also have a button in the front. My setup is almost the exact same as the one in this video here if it helps:
View: https://www.youtube.com/watch?v=q8KJPDNFrUM
I have been trying to be patient but I am not exactly pleased seeing how many views the thread has compared to the number of replies, so please answer the question.
