[SOLVED] rgb fans question
lefisvo
8
Hello all!so ive got this problem,i bought 7x https://antec.com/product/cooling/prizm-120-argb-32c.php and 4x https://antec.com/product/cooling/prizm-140-argb.php single fans without the hub offer.my motherboard is msi x470 gaming pro.there are no 3pin on this motherboard unfortunatelly.so my question is can i somehow put these fans on my current tower?
p.s tower is thermaltake view 71
p.s2 i also have aorus rgb fan commander its from z390 extreme motherboard,dont know if this helps. thanx in advance and sorry for my not so good english.
You have to buy the hub for these fans, because 11 fans (?) are too much for the MB fan_header, even you find the way to connect them to the MB without the hub, you will kill the MB.
