Question RGB Fans with pre built case
Dec 23, 2021
9
im just reaching out before I spend some money on things. I have these prebuilt case fans from CLX and they are 8 pin fan+rgb connectors, I dont really need more fans but I do want to have control over them. the hub they are plugged into is not plugged into the led switch cable from the front I/O and theres no cable to the board. Ive got some 3 pin connectors on the top of the hub that arent being used. In this case should I try to find some way to make this work? Is there a way to make this work? If not should I just buy new fans and the whole setup to make it easier on myself? I would post pictures of it but it doesnt seem that you can add them
they are all one package its an 8 pins rgb and fan connector in one. it seems like proprietary type of fans that only come from the pre built factory which they did not plug in properly
