[SOLVED] RGB fans without RGB header
Jan 13, 2019
Hello
I have Asus H110M-K Motherboard which has no RGB header and comes with only one 4pin header
I want to install 3 RGB fans and controll them with the Asus Aura software
I have this in mind : https://www.amazon.com/gp/product/B075S8PV4G/
Does that make it possible or not?
Any help would be appreciated
Thanks
Yes, you can. I had this one too, but the fans are the 120mm. Use the USB 2.0 and the sata power cable from MB to connect to the RGB controller, and the controller has four RGB headers that you can use for the fans. You can get more detail from CM site http://www.coolermaster.com/cooling/case-fan/masterfan-pro-140-af-rgb-3in1-with-controller/
I don't know, but I can use the software from CM to set up the RGB light. You can download the software from CM site too.
