lordvanko Apr 28, 2019 44 3 35 Mar 16, 2020 #1 So I want to buy this Corsair iCue 120SP RGB fan, but I really dont know how RGB fans work. Do I just plug them in the mobo and they start shining or do I have to buy an RGB controller of some sort
Solution S S scallumal Mar 17, 2020 It all depend if you have an argb header on your motherboard or not if you do then just plug in if you don't you need a controller
S scallumal Commendable Sep 6, 2017 158 20 1,615 Mar 17, 2020 Solution #2 It all depend if you have an argb header on your motherboard or not if you do then just plug in if you don't you need a controller Reactions: lordvanko Upvote 0 Downvote Solution
