R reynoldsniem Prominent Nov 18, 2017 2 0 510 Dec 30, 2018 #1 Hi, so I just got an rgb strip for my build and the connector is for a 5v 3 pin rgb header. The problem is my motherboard doesnt have a 5v rgb header or a 12v rgb header. So where can I plug this in??? I have an msi z270a-pro
Solution W W winks42 Dec 30, 2018 You can get a sata/molex adapter and plug it into the psu if you have a remote. If it’s NZXT you will need the HUE they sell.
W winks42 Respectable Sep 22, 2018 434 4 2,365 Dec 30, 2018 Solution #2 You can get a sata/molex adapter and plug it into the psu if you have a remote. If it’s NZXT you will need the HUE they sell. Upvote 0 Downvote Solution
P perdikos.jimmy BANNED Dec 29, 2018 31 0 30 Dec 30, 2018 #3 Im pretty sure you can buy a 3 pin adapter that plugs in via usb as well because i have a 4 pin that plugs into usb. Upvote 0 Downvote
