RGB LED Lights - Couple of questions about them
MagicWolf
103
Can you suggest me a brand that sells internationally? And ones that have somekind of connectors to connect two or more seperate strips as i am planning on doing a long line all around my room + pc desk etc.
I saw and learned that you can cut a strip in half where the copper is - but my question is how can i continue on using the cut out part without electricity? Can i even do that somehow? Or do i need to connect it with a connector to a brand-new strip that has an electricity available through a socket?
For instance one for the wall that i am going to use and then the part that i don't need or is too long i will cut-out to use it on the PC Table, how will i achieve that ?
Thank you,
E
If you want to light up around your room, you'd better buy something like the Philips Hue light strips that plug in your wall socket. Those for PC cases pull their power from the power supply and you can only put a couple of strips together, nothing very long.
Good luck!
Good luck!
