[SOLVED] RGB led strip compatibility
saintequila
431
5
18,795
Hi! Im not so familiar with sockets and cables from RGB led strips so I just wanna know is my Asrock B350 Pro 4 compatible with the DeepCool Addressable RGB Pro 200? And does addressable also mean it has music sync with all my other RGB components? (Ram, motherboard)
From looking the the product page (https://www.asrock.com/mb/AMD/AB350%20Pro4/), the specifications say that the mobo has a rgb header. You should in theory be able to plug rgb strips straight into that. I'm not sure if those are compatible with that header but the is some other strips that will be.
Reactions: saintequila
