RGB Led Strip Help
Help Plz
15
I am looking for a RGB led strip to put around the inside of my case to light up my components and around the bottom of my case to give it an under glow effect (I'm planning on cutting a hole in my case for the nessicary wires). I would like to have a controller or something to control the leds as well. I just don't really know what is good or how to shop for it. I was looking at the NZXT Hue, however it looks like you are locked down to the one led strip. Any help or suggestions?
Thanks!
The Phanteks Luxe case has RGB Lighting and control system built in. You can add another 1 or 2 meter strip which should handle most needs.
Now when the Phanteks cases first came out, users begged for additional FAn Controller sand these have since been released as an accessory item ($15). Maybe if enough peeps beg and moan, they will do the same for the LED system.
Otherwise Logysis has one.... FCPU closed for 30 days but you can see video here
http://www.frozencpu.com/products/21486/lit-357/Logisys_RGB_LED_Strip_IR_Remote_RM06C.html
